Results 1 to 4 of 4
Thread: Mazda 3 alarm/remote start & stereo wiring info
    Sponsor
    Auto-Links's Avatar
    Feb 2008
    Default Mazda 3 alarm/remote start & stereo wiring info
    some of you were asking in the other thread for the wiring info for the mazda 3 remote start - here you go.
    12 VOLTS red (30a), black/red (30a) + ignition harness
    STARTER 1 gray/black + ignition harness For manual transmission start: Clutch bypass is one of two Gray/Blacks in driver kick. The correct one shows ground with or without clutch pedal pressed. Requires a positive crank for remote start.
    STARTER 2 n/a
    IGNITION 1 green/yellow + ignition harness
    IGNITION 2 n/a
    IGNITION 3 n/a
    ACCESSORY 1 pink/yellow + ignition harness
    ACCESSORY 2 yellow + ignition harness
    KEYSENSE red/black + ignition harness
    DATA BUS
    POWER LOCK green/red - driver kick, door harness Notes: Lock is negative trigger thru an 1,000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
    POWER UNLOCK same as power lock wire
    DOORLOCK MOTOR yellow/black 5wi driver kick, door harness
    DOOR UNLOCK MOTOR white/black 5wi driver kick, door harness
    DISARM NO UNLOCK
    FACTORY ALARM ARM black/blue - driver kick, door harness Notes: Meter this wire while turning the key in the driver door key cylinder.
    This wire may also lock the doors.
    FACTORY ALARM DISARM black/white - driver kick, door harness Notes: Meter this wire while turning the key in the driver door key cylinder.
    This wire may also unlock the doors.
    DISARM DEFEAT
    PARKLIGHTS POSITIVE orange/white (l), orange (r) + passenger kick, harness to rear
    PARKLIGHTS NEGATIVE black/white - headlight switch
    HEADLIGHT black/green - headlight switch
    HAZARD black/orange - hazard switch
    TURN LEFT blue + passenger kick, harness to rear
    TURN RIGHT blue/red + passenger kick, harness to rear
    REVERSE green/orange or green/black + passenger kick, harness to rear
    BRAKE red/white + brake pedal switch
    PARKBRAKE black/lt. green - parking brake switch
    DOOR PIN see notes - passenger kick, harness to rear Notes: The LF door is black/yellow, the RF door is black/blue, the LR door is black/orange, and the RR door is black/green. Use all four wires and diode isolate each. These wires are also found at the Passenger Junction Box behind the glove box.
    These wires may rest at ground with the doors closed and go to an open circuit when the doors are opened. If so, then use a 452D with jumpers in default mode.
    HOOD PIN black/yellow - hood pin switch
    TRUNK PIN black/red or black/blue - passenger kick or light in trunk
    DOMELIGHT SUPERVISION black/blue to black/red - passenger kick, harness to rear
    TACH not green/stripe ac any ignition coil or fuel injector
    VSS wheel speed sensor
    GLOW PLUGS n/a
    CLUTCH
    TRUNK RELEASE n/a
    SLIDEDOORS n/a
    LEFT FRONT UP/DWN yellow/black - white/green A driver window switch in door
    RIGHT FRONT UP/DWN yellow/purple - white/purple A driver kick, door harness
    LEFT REAR UP/DWN blue/white - purple A driver kick, door harness
    RIGHT REAR UP/DWN green/yellow - green/white A driver kick, door harness
    SUNROOF LIMIT n/a
    SUNROOF OPEN/CLOSE motor part of module
    MEMORY SEAT 1 n/a
    MEMORY SEAT 2 n/a
    MEMORY SEAT 3 n/a
    HORN black - horn switch
    DEFROST
    WIPER black/green (l), black/red (h) - windshield wiper switch
    RADIO 12V red to orange/black + radio harness
    RADIO GROUND black/green - radio harness
    RADIO SWITCH yellow + radio harness
    RADIO ILLUMINATION orange/black + radio harness
    FACTORY AMP TURN ON blue + radio harness
    POWER ANTENNA n/a
    LEFT FRONT SPEAKER white/black - gray/black +,- radio harness or amp under driv seat
    RIGHT FRONT SPEAKER white/red - gray/red +,- radio harness or amp under driv seat
    LEFT REAR SPEAKER white/purple - gray/white +,- radio harness or amp under driv seat
    RIGHT REAR SPEAKER white - gray +,- radio harness or amp under driv seat Notes: The subwoofer wires are gray/white - white/blue at the amplifier.
    Interface Module: Category:
    Immobilizer Bypass Required:
    Yes Type:
    Transponder
    Jr Member MRT_MS3's Avatar
    Sep 2008
    Default Re: Mazda 3 alarm/remote start & stereo wiring info
    Very useful to whoever wants to install their own remote/starter/alarm. I see it as half of the wires you need are in the drivers side and half are on the passengers which is a pain. If you plan to do this yourself, you need about 4-6 hours to do the install. Test all your wires before tapping. Its not easy but doable.
    2008.5 CWP MS3
    Dec 2009
    Hi!!
    I am installing a remote start on my 2007 mazda 3.Does this wiring info apply to a 2007 as well?
    I have found another site that show 2 ignition and only one accessories for the 2007.
    Ive already installed the wires but havent connected anything yet to the box.I just want to make sure your wires are good for a 2007.
    thanks
    Derik
    Sr Member Gizzmo_jr's Avatar
    sticky!!
    Diesel tractor...
  1. Mazda Added Protection Warranty
    By Jeff-TheBiz in forum Buying a Mazda3
    Last Post: 05-05-2017, 12:31 PM
  2. Mazda 3 Door Lock Class Action Lawsuit
    By couch in forum Mazda3 General Discussion
    Last Post: 10-12-2007, 07:44 PM
  3. Soon to be a 3GT Owner
    By Fish in forum New User's Lounge
    Last Post: 07-14-2007, 09:25 AM
  4. Mazda Sales and Parts Contact Info
    By MajesticBlueNTO in forum Buying a Mazda3
    Last Post: 03-27-2006, 05:06 PM
  5. 17 Mazda concepts from the Tokyo AutoSalon
    By ///M in forum Other Cars
    Last Post: 12-16-2005, 03:19 PM
